Originally Posted by
96ccdd
I bought them from S&S.
But, what brand are they? Are they a "quick heat" type?
Resistance should be minimal -- < 1.5 ohms.
Check resistance between blade (take power wire off, first) and ground/glow plug casing. You could also use a test light wired from B+ and touch each glow plug spade (again, with power wire removed).
