chevy1988
Yes there is a pressure relief valve in the oil pump, main reason is to stop high oil pressure from blowing up the oil filter when someone starts the engine up and revs it up when its really cold out, 15w40 is like gear oil at -40. The only time I have seen a stuck relief valve is from extreme lack of maintaince or contamination (broken engine pieces) but I have seen 1 or 2 broken springs in my 30+ years in this business, it is not a common problem
Ron
rhsub 99K2500 suburban 6.5 code F,4L80, 4:10, FSD cooler, DSG oil cooler and lines, Dtech FSD, injectors, Isspro egt, trans and boost guages, Bilistein shocks
