I had my DMax taken to the shop for a transmission leak, techs said that it was the gasket between the transfer case and ATS Allison transmission. after installing the gasket, test drove it and it was still leaking from the same area but if you see closely ,,,it was leaking from the breather on top of the transmission. Why is it leaking from the breather?
Thanks, Mark
