Results 1 to 7 of 7
Thread: Centrifuge Oil Filtration
    Apr 2004
    Palm Beach, Florida
    Question Centrifuge Oil Filtration
    I forget who pointed to the CENTRIFUGE OIL FILTRATION system but it looks to be the best way to filter used oils be it dyno, syn, or veggy.
    Any of you use any CENTRIFUGE OIL FILTRATION setup or have hands on w/heavy diesel applications, or?
    http://www.dieselproducts.com/spinner/sp_works.html
    Sep 2006
    Anchorage, Ak
    I have a spinner 2 on the cat 343 main in my boat, as a bypass fileter. thing works great you wouldn't imagine the tar that comes out of that thing. its like rubber but its really all the soot and such from the oil, its crazy.
    Main rig-1978 chevy 3/4 f/t 4x4 8" lift 38 14.5 16 toyo m/t's. BUILT 350(soon to be 6.2) quad batteries. front and rear 15k winches. lockers F/R. dana60 front full float corp 14 rear. th400/np203.
    donor rig. 1988 GMC K3500 140k miles, th400. IFS(read CRAP) semi float 14 rear. drove it 142 miles home at 17mpg and 1/4 quart of delo 400.
    Nov 2007
    Default Centrifuge
    DBO,
    I have been thinking about how to build one for quite some time, now.
    I have a lathe, mill and all sorts of other equipment to make one. I just haven't settled on a design. I wish I could find plans.
    When I say "build", I mean the whole thing and not just take a centrifuge and put it in some sort of system.
    I want to build one for processing oil at home and one for on the road.
    Joe
    Quote Originally Posted by DA BIG ONE View Post
    ****WANTED BURNED OUT PMD/FSD MODULES FOR EXPERIMENT. ****
    1998 Silverado, 6.5TD, 210k, long bed. 1984 Chevy Customized Van, 6.2.
    1985 Mercedes-Benz SD, diesel, 220k
    1990 Ford, F-250, 7.3 liter, bad engine.
    Onan, 4 cyl. Diesel, Marine Generator.
    Onan, 4 cyl. Diesel, Stationary Generator.
    Onan, 4 cyl. Diesel, Air-cooled Engine.
    2 Briggs/Faryman Diesels to rebuild.
    Nov 2007
    Is anyone here that has a lathe and mill and would like to collaborate on the building of a centrifuge?
    Joe
    Quote Originally Posted by joe bleaux View Post
    DBO,
    Joe
    Apr 2004
    Palm Beach, Florida
    Default Patent issues, or?
    Patent issues aside, thinking building one for personal use would be cool.
    It would have to have some quality bearings. Compressed air, even tapped from turbo compressor, and oil pressure to spin device would work, higher the rpm's the better unit will work.
    I'm guessing the unit does not fill up with oil because it works on centrifugal force so a big drain is needed.
    I see lots of big machines use this device in concert w/filters so it has value in the oil cleaning department.
    Feb 2008
    Kentucky and Clemson SC
    I have the dieselcraft 0c50 cetrifuge that i use for my veg oil cleaning. I filter it with a strainer on my transfer pump and then run it for about four cycles. Oil comes out looking like sweet tea, cleaner and cheaper (in the long run) than using bag filters like i used to do. I have mine mounted on a wooden frame along with a Grainger gear pump to drive it. I put the frame on top of a 55 gallon drum. I would reccomend it if your are looking to go the veg route, Cleans oil great.
    Sold: 98 2500 ext cab long bed 4x4 auto 166k, Lubrication Specialties oil cooler, FSD cooler, Walking J "feed the Beast" mod, Heath HD lift pump, SSdiesel turbo back exhaust, Heath mechanical boost controller, Softtopper camper top, boost, egt, fuel pressure gauges
    1970 El Camino SS, built 355, aluminum heads, Lunati cam, intake, 800 cfm edlebrock, Tremec 5 spd, QA1 Coil over all around, Wilwood discs up front, 3.73 Posi 12 bolt, Viper Red
    2012 Audi A3 TDI- Love it! 45 mpg!
    Apr 2004
    Ottawa, Ontario
    Log onto:
    http://biodiesel.infopop.cc
    and do a search for centrifuge. Lots of stuff there.
    Bill
    94 Cadillac Fleetwood (sold)
    08 Aerolight 23TT
