No diagram, but it's really not too complex. From the tank pickup it goes to the lift pump, filter, and injection pump. The injection pump has a return line as does each of the injectors. They are all manifolded together and plumbed back to the tank. The filter has a water drain that is connected to the brass valve on the thermostat housing and also contains a fuel heater element. There is a secondary pickup in the tank a couple of inches above the bottom that comes into play if the main pickup gets clogged.
