Engine Starting Speed
I have a problem related to starting, not fuel, batteries or cables. All those have been checked and or replaced. My problem is that for the last 6 weeks or so I have noticed what I think is slower engine RPM during the starting process. This led to replacement of batteries and the alternator. While they all tested bad, it did not fix the problem. The engine consistently makes two to three rounds and starts and runs fine just noticibly slower starting speed. My question is before I spend the money for a new starter does any one know of a way to truley test the starter drive for a low torque high current draw situation. The symptom is slower starting RPMs and starter motor noise that sounds labored what ever that means.
Currently 199450 miles.
Original Starter.
Thanks in Advance for your help
Reason: Footer Wrong
1995 C2500 6.5TD
Daily Driver
FSD Cooler
HV Oil Pump
Cooling Upgrade
210K+
