Results 1 to 10 of 10
Thread: Hello again from England
    Apr 2008
    North Devon ENGLAND
    Default Hello again from England
    Hi everyone, Ive had a few 5.7 diesel over the years and sold my last one a little over a year ago and missed it pretty bad so yesterday I went and bought this Chevy Caprice Classic wagon with a 6.2 diesel in it
    Shes runs real strong and sounds great hope to get to know ya cheers for now craig
    Chevy Caprice Classic 6.2 V8 Diesel "Let That Diesel Smoke Roll"
    Apr 2008
    North Devon ENGLAND
    Hi Jim, I know the guy really well where she came from and he told me it does about 30mpg on a run and about 25 round town.
    Ive done about 170 miles now on just over 1/4 of a tank.
    It still has its four speed auto which helps.
    May 2005
    SE Wisconsin
    Very Cool.
    1997 GMC Savana - 6.5 TD
    1967 Jeepster - Stock
    1986 Jeep CJ7 - Stock
    Need pictures of the engine bay!
    Stupid question, but is this a retrofit or did they actually come stock that way 'cross the pond?
    Apr 2008
    North Devon ENGLAND
    Hi, I'll sort that out over the weekend for ya. I was going to put some pics up of the motor as I would like to try to find out how old it is and which type. Am I right in thinking they did a few diffrent models of the 6.2?
    It is a retrofit as thew 5.7DX died at some point and the chap thought it would be better just to fit the 6.2 in.
    Apr 2008
    North Devon ENGLAND
    Here you go as promised
    Only the A/C and cruise was lost in the swap. I don't mind about the A/C as it don't get that hot here in the U.K but I do miss the cruise.
    Pretty clean little install there!
    You should be able to retrofit cruise back into the little beast.
    Very nice!
    How are the cold starts? I can see that you don't have a high-idle function (no wire going to the high idle solenoid), and I can't see if if you have a HPCA (cold timing advance) wire hooked up or not.
    Great fuel economy! Thanks for sharing...
    I copied this thread to the "Conversions" forum to give it a little more coverage in the conversion topics.
