I've used it for extended periods with no noticeable negative effects. It was run through a filtr and I added stanadyne blue fuel treatment.
Home heating oil is not subject to cetane levels and can be low therfore the additive to boost cetane,It does however have higher BTU's per Gal and that is where the bang is! It also is higher in sulfer and has considerably better lubricating qualities for pump and injectors. Keep it clean and your truck will love it.
Dave
99 sub 2500, 326,000mi, 4:10, 265-75-16 rubber, remote Dtech fsd and turbo master from Heath Isspro pyrometer and boost gauge-Kennedy, 1.94 TDCO, 3" custom bent exh.
07 Suburban,08 LMM, Allison 6 speed.
