Results 1 to 6 of 6
Thread: You put Gas in tank,?
    Smile You put Gas in tank,?
    During WWll Gi's found a field of new German trucks, they were short of vehicles and wanted to use them, problem,they were diesel and US Army did not have access to Diesel fuel. In the Batallion there was an automotive engineer who solved the problem,, just add one quart of 30W oil to each gallon of gas.. wal la problem solved Army used the trucks for weeks untill Diesel was found. One day While driving my Merceded 240-D I ran low on Diesel a few years ago before Diesel was so prevelant and when on fumes i pulled into a gas station and put in 4 gal of gas and added 4 qts of oil, Mercedes ran great to my destination of over 50 miles no loss of power, no knocking,,couldnt gtell the difference,, kept car for another 100,000 miles
    In an emergency, I'd try it.... However, what might work for one diesel engine might not work or could actually damage another. The risk of not knowing what might happen and the high cost or repair usually keep people from experimenting.
    Gasoline has an octane rating, which is a measure of its ability to resist spontaneous ignition. Diesel fuel has a cetane rating, which is a measure of its ability to spontaneously ignite. A high concentration of gas could prevent a diesel from starting or running. A mix of some percentage is usually where the reported problems arise. Gas is more volatile when buring - diesel less so. The percentage of diesel fuel will ignite like it should, which then ignites the gas percentage, which burns faster and more intensely than diesel fuel.
    Dec 2006
    Saint Clair Shores, MI
    Germany ran most of there stuff off of diesel, in fact they made the fuel from coal, just like is being discussed now. The german vehicles used a different combustion chamber shape then modern diesels. Look up "hyper-cycle" this is the same design used in the US military "multi-fuel" engines. The multi is rated to be run at up to 80% gasoline for "emergancy use", meaning yes it will get you out of the firefight, but its not good for the engine long term.
    1985 M1008
    (k30 for the civi' minded people)
    my photo album
    6.2L (banks turbo installed)
    6" suspension lift
    38.5" ground hawg radials on H1 double-beadlocks
    cross-over steering
    rear disc brakes
    Dec 2006
    Quote Originally Posted by Pete Brenenstuhl View Post
    I would love to hear the source of this story.
    1985 M1008
    my photo album
    6" suspension lift
    cross-over steering
    rear disc brakes
    Sep 2006
    Brooker, FL
    Actually, the octane rating (simplified) is the measure of the speed of the combustion. Normal heptane has an octane rating of 0; iso-octane, 100. Engine "knock" comes from a combination of too-low octane (for the compression ratio) and/or too-advanced timing. "Spontaneous ignition" is called "preignition" (one of the other two causes of "pinging", and is the result of deposits in the combustion chamber that retain enough heat to ignite the fuel-air mixture before the plug fires; it is not considered a characteristic of the fuel. The third source of "pinging", BTW, is "detonation", caused by a too-lean mixture.
    Octane is measured by one-cylinder engines, which have a computer controlling parameters; the more relaxed parameters are the Research Octane number. The parameters for the Motor Octane number are more restrictive. Years ago, companies posted only the Research number (since it was higher). The Feds required the current number, which is the average of the two.
    Cetane rating (simplified) is based on a mix of cetane and napthalene, and is the time delay from injection to ignition, measured from the start of each event, and like octane rating, measured on an actual, expensive, little engine.
    Sep 2005
    Washington, DC
    Smile
    Are you the Pete Brenenstuhl that ran the sound & light department at the Sheridan Park Hotel In Washington DC back in the 70's? If so I worked for you then. How are you doing?
    2015 VW Passat TDI SE, 6 speed manual
    Past Diesels
    1980 MB 240D, 4 speed manual
    1983 GMC Vandura 3500 Nu-Wa 23' Class C Motorhome
    6.2L Diesel, Turbo 400
    1985 MB 300D Turbodiesel, auto
    1992 Chevy C2500HD 6.5 Dieselturbo, auto
    1994 Chevy C2500HD 6.5 Dieselturbo, auto
    2010 VW Jetta Sportwagon TDI, 6 speed manual, sunroof
