I am going to install an engine oil temperature gauge on my 06' LBZ. I know that there are two 1/4" pipe plugs in the oil filter housing casting that would work perfectly for the sensor if the sensor probe does not block any oil flow. I also notice that near the oil drain plug on the pan there is what appears to be a factory electric oil temperature sensor and wonder if it would be possible to tie in there with an electric rather than mechanical gauge. Where are folks installing sensors on this engine?
Randy
