Originally Posted by
SoTxPollock
Side note: By the way JBPLOCK, you said SWR said the wear was 6 to 7mm size, that's not millimeters obviously, you meant microns right?
SoTx,
Yes thanks for catching this .. microns not mm (post has been edited)
Also ..
Idle_Chatter
Kennedy Mega Filter installed post-OEM ....
... sometimes difficult to change after a long use interval (filter stuck to filter head).
Tom,
I also had a tough time breaking my first Mega Filter loose ... when installing the second one I removed the O-ring and coated it with some Parker Super O-lube (similar to silicone grease) .. When the time came to change, it came of with out any trouble ..
Bill
98 K3500 6.5,SOLD
