2002 Chevy Silverado LTCC, SB,
Added Racor RS60s filtration post OEM, at 20,000 miles.
Original injectors, 132,000 miles, they're not as quite as they used to be, but still run great.
Never had any kind of problems, starting, running etc. Love that truck.
ROI, supposedly the filtration is down to about 2 microns so I don't expect any problems from particle errosion. I'm sure this has already saved GM some money on replacement of the injectors, next year come July it will be my nickle if they go bad. I jus think its an investment in assurance of continued top performance. I've always maintained my vehicles like I was going to walk out of the house in the morning and drive straight to New York without haveing to check anything first.
Side note: By the way JBPLOCK, you said SWR said the wear was 6 to 7mm size, that's not millimeters obvously, you ment microns right?
