Holset Turbo and LB7's
Is there any advice or contacts available in regard to installing a Holset turbocharger on an LB7 Duramax? The truck is stock and will remain as such...with the exception of planned 5" exhaust and cold air intake system. Also new injectors if/when needed...but nothing much more radical than stock if any.
In terms of the model...I'm thinking HX40 ~ HX50 and whatever combination of exhaust housing size and wastegate control is needed. Which ever matches/exceeds the IHI performance.
I know ATS, BD etc etc makes some decent upgrade kits. I would like to try a Holset however. I've always been pleased with their performance on other trucks.
2002 Chevrolet HD2500 4x4 LT
Extended Cab - Shortbed
Duramax LB7-Allison 1000
Charcoal Metallic Ext/Int
