Have a whistle from the turbo area on deceleration with exhaust brake engage - 2004 C4500 LB7.
This is the second time around for this fix, first was under warranty - this time will be on my dime so I want to get it right!
Anyone know of a better set of turbo to manifold gaskets? Obviously, mine aren't holding up under the rigors of heavy towing and the factory C4500 exhaust brake's peak backpressure. I have experienced (created) both failures, ironically on the same downhill grade (Monteagle, TN on the way to FL with heavy boat) always with the exhaust brake on.
Need...MORE GASKET... (...or maybe less backpressure?)
