Vacuum line from Vacuum Pump
the Vacuum Pump has died and I am replacing with a new one... Apparently the USA models only use for the Turbo but mine needs it for controlling the vents on the A/Cond.
Mine has a 4mm plastic hose that connects between the Pump and the sensor on the Rocker cover - about 12-13 inches long and I broke mine.
It is adapted to a rubber hose at each end.
Does the US 6.5turbo (F) motor have this same plastic hose? If so any ideas on part no. or who stocks the part?
Noel
Noel
1998 (Badge Re-engineered)RHD GM-Holden Chevrolet Suburban K2500, 150k miles, Turbo Diesel 583Nm 200Hp, New 4L80E, 3.73:1, Rebulit T/case with New Housing, standard 245's factory 6.5" wheels. No Mods. Car Code OBDII interface with Enhanced GM data, test & command modes, data logging, live data etc.
Toyota HZJ80 Landcruiser 4.2L Turbo Diesel, 195k miles, 430Nm 210Hp. Mitsubishi Water Cooled Turbo, Through bonnet Intercooler, Advanced timing and increased fuelling, 12 psi boost, Boost gauge and post Turbo pyrometer. 5 Spd Manual.
