Thread: Stock LBZ intake.
    Jan 2009
    Southeas TX
    Default Stock LBZ intake.
    From the extensive reading on this forum I have done it seems the general idea of the stock intake on the LBZ is more than enough. However I have also read (on other forums) that there is a modification that can be done to make it a little better. I believe the modification has something to do with the removal of the dust centrifuge? I am new to all the diesel stuff even though I was a heavy equip. mech. for 12 years. The only diesels I work on were mechanical injections with with electrical solenoid over mechanical fuel shut offs. I got out of the trade just prior to everything having a ECM. Any help on this matter or links to other similar post are greatly appreciated. Thanks
    2007 Silverado CC 4x4 SB, D/A LBZ, edge insight w/egt probe, Transfer flow fuel/tool box, BD exh. manifold, Magnaflow T-back 4", more to come.
    Personally, I would leave it just the way it is. Taking out the centrifuge is not going to give you more power, only allow more junk to hit the filter. I run my 2007 stock except for my tuning.
    Jan 2009
    Southeas TX
    I appreciate the advice. From what I have read most everyone with the LBZ and newer leave it stock. As far as the air filter do you leave the stock filter in as well?
    Dec 2005
    Klamath falls/keno Oregon
    speaking of air filters..i have the optional "big" air cleaner..i dont think i should trust the little guage telling me when to change it...or should i?
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    I replaced the OE filter on my 2007 at around 25k. I was really amazed at how much sand came out of it especially considering I don't travel a lot of dirt roads. I found that a few gentle taps and the grit came right out in a circle on the shop floor. The filter minder hadn't budged yet, but I know 25k is a bunch for an air filter so I just changed it.
    Fitting the new filter can be quite a PITA also...
