Thread: tie rod end diagram
    Dec 2007
    Default tie rod end diagram
    i need to replace my tie rod ends does anyone have a diagram or drawing show it and hopefully listing the parts so ill know what to or for my 93 3500 4x4
    thanks for the help
    Sep 2002
    Fort Wayne, IN
    Quote Originally Posted by raw View Post
    thanks for the help
    raw,
    I replaced all the tie rods on my '96 K2500 Sub a couple of years ago, along with the pitman arm and the idler arm. I bought everything from Rockauto.com. I didn't have any diagrams when I replaced these parts, everything was straight forward.
    I do have a copy of the SI program, but it only goes back to 1998 or 1999. When I had questions, I would look up the 1999 Sub for comparision. But in for doing the front end work, I didn't need the program.
    Bill
    1996 K2500 Suburban - Purchased in Sept. 2002 - 297K miles
    Only mods - K&N filter, Greg's Oil Cooler Lines, Home-made FSD heatsink, Kennedy quick heat glow plugs, LED interior lights, Kenwood stereo, 2001 GMC aluminum rims. AutoMeter Guages (boost, EGT, TransTemp)
    2007 GMC Acadia SLE - wifes car.
    1987 Buick GN totally stock - 48K miles
    Yep, I did mine a year and a half ago. Went to RockAuto, put in my year and model, and got all the parts. I found it easier to replace the adjusting sleeves ($12 ea) than screw around with the rusty messes that they had become. Went with all Moog parts.
    Oh, and two more things.
    The hardest part I had with the whole job was getting the pitman arm off. Other than that it was just a matter of removing the old and replacing with the new.
    And a short time later one of the stabilizer end bar links cracked. While I was in there, I should have replaced those as well - only another $36 for the Moog part.
    Just an update. Have the truck in for the annual state inspection and got a call from them - one of the inner tie rod ends was bad and needed to be replaced. Roughly 35K miles on it since I replaced it the first time. Seems like it should have had a longer life than that...
    History was that I bought the truck at just under 132K and the first thing I had to do was replace pretty much the whole front end - tie rod ends, pitman arm, idler arm, etc. I do have a set of 285/75-R16 tires on it and take it out for some trail riding, but I'd have expected at least 60K to 80K out of components.
