Thread: Mechanical fuel pump
    Feb 2009
    Kadina, South Australia
    Default Mechanical fuel pump
    G'day from down-under,
    I'd been having a bit of diesel dripping from the mechanical fuel pump on my n/a 6.5 and suggested to my spanner-man that we should be able to do away with it altogether.
    I also have 2 electric lift pumps (one behind the "top hat" in the middle of the "V" and the other down the back above the main tank), so there should be no need for the mechanical lift pump.
    Just wondering if other owners have also done away with the mech pump?
    Regards,
    Roachie
    2000 Nissan Patrol 4x4 with Chev 6.5 n/a diesel V8. 35" Mickey Thompson MTZ. 3 x batteries. Engel fridge running 24/7. Onboard air compressor and tank. 4" lift. Amsoil dual bypass oil filtration. plus heaps of other stuff.
    AB Canada
    G'day from the far north[Can].
    with 3 lift pumps on it you could pump crude.
    why 3 LP's? but you can skip the mech pump, altough they are less failprone than electr ones. you can leave it on to block the hole. if you dont want to have it rattling along, take the pushrod out.
    hope this helps.
    98 GMC sierra 2500 ext cab 4x4 auto tr 6.5 td 252000 km. needs new engine, next project
    95 GMC sierra LE 2500 ext cab sh box 4x4 auto tr 6.5 td 328.000 km. my wife's truck .remote pmd on cooler
    89 GMC sierra SLE 1500 ext cab 4x4 auto tr 6.2 720000 km engine swap at 665000 km because of broken oil cooler line. 6 bolt wheels.
    Waldon wheelloader repowered with a 6.2 na
    Feb 2009
    Thanks Simon.
    I guess I've done a bit of overkill by adding the 2nd electric pump, but the rig had the mechanical + one electric pump when I bought it.
    It runs 2 fuel fiters plus a de-bug unit ( see www.morison.com.au ) to combat any problems from algae etc which can sometimes be a concern in the outback regions of Australia.
    With this extra restriction, I figured if I added a 2nd electric pump down the rear, it would ensure that I was pushing the fuel up the front. The new pump is just a small Facet pump of about 5psi capability.
    Thanks again,
    Roachie
    For your engine, 5 PSI is about all you need or want. Over 10 PSI, you can have IP issues (skews injection timing). Any pressure more than zero is good (under all conditions, of course).
    I am no a fan of electric pumps. Especially when reliability is needed. Electrics fail often and without notice, comparatively. Electrics are good for engine-off priming, but mechanicals excel beyond that. I suggest replacing your mechanical with a mechanical. No harm in having an electric in stand-by, though.
    Feb 2009
    Thanks for the advice Dmax
    Cheers,
    Roachie
