Thread: Kubota V3300TE need some help
    Feb 2009
    Rockwall,TX
    Default Kubota V3300TE need some help
    I have a V3300TE that I am doing some research in putting this in my Jeep TJ 1997. I have an idea of what I am going to do on A/C Brake booster will by Hydro since I am funning Full Hydro Steering front only, glow plugs etc. I am also need assistance definitely on the transmission side of it. I have the AX15 in it for the 2.5 4Cyl and I want to stay manual. I know that it is a Sae 4.
    Thank you,
    Feb 2009
    Rockwall,TX
    It came out of a 26000 capacity Combilift.
    I am fixing to tear it down and see what it is going to take but I am shopping
    I would definitely dump the AX15, as they are a very weak tranny. It probably wouldn't last long behind the torque of the diesel. An NVG3550 would be a better alternative, also found in later model Wranglers.
    I don't have any idea about the bellhousing issues, though.
    Cool swap!
    Feb 2009
    Rockwall,TX
    Sweet so I got my Bellhousing and flywheel back. I thought that we wouldnt get it back form the place where we bought the new engine from but they had kept it and it was BRAND NEW. So at least I have that back off my list of concerns. Back to the Transmission and Accessories like AC compressor, Alternator which there is a spot for it already and my Power steering option. I hope to add a compressor to it for Trail use. Now I need to just lay out my plains and start looking at the whole picture.
    Any help would be great from guys that have already done this.
