Thread: Good Deal?
    Aug 2007
    Nashville Tennessee!
    Default Good Deal?
    http://cgi.ebay.com/ebaymotors/6-5-6...Q5fAccessories
    this is extremely cheap from what i've been reading.
    i've got my injectors out and DIY rebuilt. the only thing that would make it better would be these nozzels or new stockers.
    EDIT:
    i guess the better question would be.
    are there any adverse side affects, is there any down sides to installing these.
    Nov 2008
    Tromsoe Norway
    Hi
    The deal looks good, but ?
    What brand is the nozzles.????
    You will have to have someone to change them, and adjust them for you.
    You cant install the into the injecors without adjusting them, and pressure test them.
    50HP???? i doubt that..i would think something like20-30 hp with modified exhaust.
    you should have freeflowing exhaust at minimum, stock could be restrictive when adding power. The temp would also rise a bit when adding fuel\power.
    i would buy a known brand like Bosch or Stanadyne to be safe.
    since he is not mention the brand it could be from China.
    Ask him before buying.
    New sub. 1996 6.5 ls 1500.
    1994 Suburban K2500HD. 6,5 TD 251 000km. sold
    3,5 inch exhaust, no cat.
    Marine injectors. Removed snorkle
    opened intake plenum. 3 gauge pillar. EGT.Turbo.Tranny temp. Fsd Cooler, resistor nr 9.
    Top mounted Air to Air intercooler. Kennedy Turbo master
    intercooler is installed.
    look in: http://www.thedieselpageforums.com/t...ad.php?t=37313
    Read this thread before you go any further:
    http://www.thedieselpageforums.com/t...ad.php?t=26767
    Aug 2007
    i've done a lot more research and these are not a complete waste of money but they are NOT a starting point
    these marine injectors are a "supporting mod"
    much like upgrading to a HI performance coil and plug wires/spark plugs on a gas engine.
    these will support and enhance any existing power adder but they themselves are not a "bolt on" high performance upgrade.
