Originally Posted by
More Power
The most frequent cause of the sort of problems you're seeing is the pushbutton switch panel. I had the same problem, and simply replaced the switch panel with a new one. Solved the problem... and the local dealer parts guys said they replace them quite often. Mine was replaced about 3 years ago, and it's still working fine. It was about $40 if I remember correctly.
On another note, my wife's AWD Chevy Tahoe also had problems with its 4WD indicator system. Again, I simply replaced the switch panel.. Problem solved.
Jim,
Thanks for the info.
I pulled the 4wd fuse more than a week and hundreds of miles ago. I've had no more faulty indicators. The service 4wd light comes on every time I start the engine but that is understandable.
Would this argue that the fault is in the encoder or might it still be the switch unit? I would think that no faults while the fuse was out would point more to the encoder.
03 Chevy 3500 LT DRW D/A CC LB 4x4
03 Lance 1130
