some good reading on vacuum pumps and crankcase evac
http://www.dragstuff.com/techarticles/vacuum-pumps.html
motor specs for the smog pumps motor....this thing is a fast mover!
http://www.igarashimotors.co.jp/prod.../037A_5066.pdf
I suffer from CLSA, there is no end in sight....I just Can't Leave Sh!t Alone!!!!
86 6.2l 2wd burb, 3.08 gears, 700r4, 255/60-295/50-15 on eagle alloys, hummer intake manifold, open air cleaner, new: injectors, timing set, water pump, hydrooost & MC, 140amp CS144 alt, M90 supercharger in the works.....
Newer style tail lights, HID headlights, white faced tach gauges, new dash pad, black carpet and a killer hand built fiberglass sub box and door pods.
