Welcome!
To help answer your question, the platform for your 'burb did come out in 1988. However, GM continued to make the old body style (73-87) trucks in the cab and chassis, Blazer, and Suburban lines up through 1991.
So, if the bumper came off a 1990 1/2 or 3/4 ton, you know you're safe. If it came off a 1 ton, you'll need to find out which body style it was.
