Results 1 to 2 of 2
Thread: '93 Steering Column to '89 Suburban.
    Lubbock TX, USA
    Default '93 Steering Column to '89 Suburban.
    I've got a parts '93 pickup (well, half of a pickup) that has a good tilt steering column in it that I'd like to use in an '89 K2500 Suburban. These are different body styles, but similar columns.
    So, will they interchange, I'd like tilt in the Burb, because I can't drive unlesss the wheel is in my lap.
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
    Don't know about a direct swap, but I imagine anything is possible as far as a column swap like you propose. The 1993 has the ignition switches located about midway down on the column. There may need to be some adapting (wire mods) to get it to work correctly.
