PM me with your email address and I'll send you a pdf on the 12v conversion.
Is there any particular reason to do this as there is no problems running the 24volt setup. I run with the 24volt system over here with no problems and use it to jump start all sorts of equipment from big rigs to scissor lifts etc.
I have all my accessories (6 spotlights, Beacons, CB etc etc) wired to the second battery to even up the load on each alternator and battery.
I also removed the blackout driving lamp and fitted a second stinger plug wired for 12 volts and fitted heavy duty croc clips to one end of my stinger leads(jump leads).
regards from Scotland
Simon
84 M1009 CUCV 6.2 'J' spec everyday runaround
83 M1008 CUCV everyday runaround/workhorse.
83 M1008 CUCV 6.2 'J' spec budget project off roader.
