Hydroboost leak
I've developed a serious leak on my hydroboost brake assist. Every time I apply the brakes, a stream of power steering fluid pours out between the master cylinder and hydroboost system. Is there a seal that goes between the two? Or is this an internal problem with the hydroboost? If so, can I repair/rebuild it, or does it require replacement?
This is on my '95 Tahoe. It's currently leaking enough fluid that I have to refill the power steering reservoir every four to five days.
Thanks,
