Note: This forum thread contains quite a few images. Send me a message if you're having trouble seeing these images. If you're not already registered here at The Diesel Page Forums, please do. It's free. Register Now! You may need to register to see everything - or post here in this thread. I urge you to do both! Did I mention it's free? And, we don't sell or use your info for any purpose other than to help you use this bulletin board forum or answer your questions.
Lil Red - Duramax Diesel Power Project
Rocket science is a whole lot more entertaining when you actually get to drive one! Yes, you can install a Duramax 6600 and Allison 1000 into a 1988-98 GM 2/4 wheel drive pickup truck, whether 1/2 ton, 3/4 ton or 1 ton. And yes, you can also install the D/A into a 1988-98 2-door/4-door full size SUV (Tahoe, Yukon or Suburban).
This topic thread includes a discussion about a new body style (NBS) dash conversion for the old body style (OBS) 1988-1998 full-size trucks and SUVs. The new dash is not required to produce a running and driving Duramax conversion, though I do recommend modifying your existing dash to accept the instrument panel gauge cluster that matches the model year of your Duramax engine. It's not all that difficult, and having the instrument panel gauges will enhance your overall Duramax conversion. I cover portions of the dash installation here in this topic thread, but more information is included in the helpful Guide book we offer concerning Duramax/Allison conversions (see my signature here).
Lil Red - the Duramax/Allison conversion project truck shown here was first driven in April 2004 - and it became the very first privately owned Duramax/Allison conversion in a GM vehicle. The Diesel Page literally wrote the book on Duramax 6600/Allison conversions, and we designed the Duramax Conversion Motor Mounts that allow for a bolt-in conversion.
The primary mission for this Duramax Diesel Power Project was to determine the feasibility of using the Duramax 6600 and Allison 1000 automatic transmission in a range of conversion projects, including the GM full-size trucks and SUV's from 1967 onward (with slight modifications - depending on model year). This Lil Red project shown here was the beginning of all that. The above photo was taken in 2002, just after receiving the new engine, transmission and transfer case.
In addition to the K1500 truck featured here, we also completed a 1987 Chevy C30 Duramax Diesel/Allison 1000 Conversion here in TheDieselPage.com. That 1987 Chevy C30 conversion is another of many conversion projects we've been a part of.
A 4" exhaust system, 4" polished stainless exhaust tip and Bilstein HD shocks were installed after the body work and paint had been completed. A custom exhaust system was chosen because we needed a 4" tailpipe without pre-welded hangers to work for this rather unique application. There is no muffler or catalytic converter installed, which means the truck sounds a little more like a hot-rod. The 2001 LB7 48-state emissions regulations did not require EGR, a catalytic converter or any other exhaust aftertreatment - one huge plus for the 2001 LB7. The addition of a set of CalTracs traction bars help control axle-wrap during a launch. Kennedydiesel.com was helpful in working with me on some of these items. I also eventually installed an ATS Allison Extreme transmission to help explore the performance potential of the Duramax.
Prior to May 2004, we had been looking for just the right set of tires & wheels before we finally settling on the silver finished factory Chevy SS 6-lug 20" x 9" aluminum wheels. The matching Goodyear Eagle tires in 275/55R20 were an excellent choice, being almost 32" in diameter and more than 11" wide.
The original 10-bolt ½-ton rear axle was replaced in late 2004 with a custom disc brake equipped (using factory GM 2003 K1500 rear disc brake components) GM six-lug 9-1/2" 14-bolt semi-floating rear axle that had been removed from a low mileage 1997 GM 1500. This rear axle was rebuilt by Randy's Ring & Pinion in Everett Washington with a new Eaton Posi-traction differential, new 3.42 ring & pinion and all new bearings and seals. An all new rear driveshaft was manufactured incorporating a 1350 series rear U-joint to match the rear differential pinion yoke and a new 1410 series U-joint & yoke/slip-joint at the front to match the Allison/NVG-263 output shaft. There has not been any detectable vibration or any other unusual behavior while using two different U-joints in this rear driveshaft. The 4WD front driveshaft was similarly manufactured using the appropriate yoke/U-joint at each end. This combination has been run at the 1/4-mile track at up to a 130-mph (in 4WD) without any sort of problem, even with more than 600 horsepower and 1200 lb-ft of torque.
This project was primarily about the conversion process, but it also provided a tremendous opportunity to learn more about the power-train. Because this truck would be used for promotion, the completed engine/transmission conversion had to appear to be a factory installation. In fact, most people actually do think this was a factory installation. I urge all those who embark on their own conversion to work toward the same goal - a factory "look". This will increase the value of a converted vehicle by as much as $20,000. For years now, late model 2500 series Suburbans that have a factory looking and performing Duramax/Allison conversion were being sold for at least $20,000 above the Kelly Blue Book vehicle pricing guide, simply because of the clean install of a D/A and the rarity of that combo. There was a time when people would follow D/A Suburban owners into parking lots, rest areas and fuel stations wanting to learn more about the owner's Duramax 6600 powered Suburban and their wish to buy it on the spot. And... you'd be surprised at how many individuals began businesses converting Suburbans as a result of what we've done and documented here in The Diesel Page.
The above is about midway through a 12.9 second run, showing Lil Red squatting the rear and lifting the front all the way through the 1/4-mile. This photo was shot during one of the bracket runs, where they handicap the faster trucks - allowing the slower trucks to leave first off the line by some whole or fraction of a second. In this case, the Dodge got the green light about a half second before Lil Red. The Dodge was overtaken well before reaching the lights.
This truck has appeared in the January 2007 issue of Diesel World magazine, the May 2006 issue of Diesel Power magazine and in three separate issues of Truck Trend magazine.
TDP - Jim Bigley
The Duramax Conversion Guide - This new second edition includes glossy full-color photo-quality front and back covers, a completely updated and revised interior that includes 62 glossy pages (17 B/W + 45 full color pages) filled with updated photography and graphics, along with even more information that will not only help you succeed, but will inspire you to complete your project.This professionally written and bound volume illustrates what you'll need to know when installing a Duramax 6600 diesel engine and Allison 1000 automatic transmission into a 1988-98 classic OBS (Old Body Style, like that shown here) C/K GM pickup truck or Suburban, plus boats and even a Duramax/Allison conversion in the 1980s "square body" trucks.
3/14/2023 - Keep reading! This forum thread includes blog entries over time about Lil Red and its Duramax conversion. If nothing else, this shows how well the truck continues to run and perform since its completion, and it shows just how much fun Lil Red is to drive and how people we meet along the way respond to it. Check back now and then to catch up, or subscribe to this thread so you'll be notified via email when a new post has been added (using the "Thread Tools" link above the first post in this thread). In the meantime, if you have a diesel event scheduled for this year somewhere in the northwest, let me know. Lil Red and I might just come to see you!
