I also inspected the supply line with the truck on a hoist, it appears fine (no obvious damage or kinks) but may replace entire supply line anyway, to rule out the possibility of an intermittent collapse... which would be nearly impossible to see unless you are under the truck when the high fuel request was happening!!!
(BTW it doesn't take WOT to trigger my P0087. It does take a fair load (12K#), warm/hot engine temps, and a reasonable climb - one that would put the %LOAD at 95% or better on the OBDII data...)
