Page 12 of 12 FirstFirst ... 289101112
Results 221 to 224 of 224
Thread: P0087 fuel rail pressure low limp under high loads
  1. #221
    Geneva, IL
    Default Continuing the Saga
    Hi,
    Just returned to Illinois from Quartzsite towing the fiver. I have122k miles on an '09 LMM. No problems going down in January, but several 0087 episodes on return last week. Absolutely stock truck with auxiliary filtration and regular Power Service throughout its life. Regular filter changes. Regular Chevy dealer service at the same competent location. No lift pump (duly noted, John).
    Obviously, working through this thread gives possible short and long term answers. But my solution for getting home the last 1,000 miles -- starting in western Oklahoma -- was to keep post turbo EGT's in the 1,000 degree range, and never more than 1,100. I used that as a proxy for the temps the injectors and incoming fuel were experiencing. I did this by doing a lot of manual gear selection on hills. I recall only one post in this entire thread that mentions that approach. Hmmm.
    I will figure out my future with this truck somehow. But when other brands of diesels are notable for much longer injector life, it makes me wonder what GM has stuck us lifelong, committed customers with.
    FWIW.
    Rich Phillips
    Member #27
    2019 K-2500 Crew Cab Z71
    Cedar Creek Silverback 33RL Fifth Wheel
    In The Past: '82 6.2 Jimmy Blazer, '93 6.5 GMC K-2500, '01 DMAX K-2500, '09 DMAX K-2500
  2. #222
    Geneva, IL
    Hi,
    My dealer had it for two days, and as I expected, found nothing wrong -- injectors test solid, no codes left, and absent the load from towing heavy, on hills, while hot, no way to get their equipment to register my issue. They report all fuel lines solid, the fuel cooler clean, and no leaks anywhere.
    These are two guys who know the truck since new, have serviced it thoroughly and regularly, and otherwise have my confidence. So for now I'm going to drive on and see what the future holds.
    They did offer a thought that freeing up the exhaust might help keep overall temps down and thus keep the returned fuel cooler. Coming from a dealership, I found that interesting. Any thoughts on that from anyone?
    Rich Phillips
    Member #27
  3. #223
    Dec 2000
    Hawaii/Arizona
    Default P0087
    Hi Rich,
    I agree with the dealer that opening up the exhaust would help cool the motor by lowering the EGT a little. I do not think it will get you a substantial drop in fuel temperature. Additionally, the noise caused by most large exhaust systems will make for a very long trip from Illinois to Arizona next year.
    My post about the P0087 code was the one posted just before your post (take a look). If I keep plenty of fuel in my fuel tank it seems to cool the returning hot fuel and stop the P0087 problem. When your truck threw the p0087 code did you have over half a tank of fuel? I think a second fuel cooler would cool the returning hot fuel a lot better than a larger exhaust system. Just my thoughts on the P0087 code.
    Good luck
    John
    *2007 Pontiac Solstice.
  4. #224
    Geneva, IL
    Hi John,
    Thanks for the response.
    I usually fill up at the end of the day's run with the fiver, so I can get a fast start in the morning. And I have been getting a few hours of clean performance -- until the tank is lower and the day is warmer. So refueling more often might help, although it would slow the day's progress.
    I have pondered adding another cooler. Insofar as I recall, nobody in this thread has mentioned actually doing it, or a supplier with suitable hardware. So that is an option with dangling questions...
    And yeah, the exhaust noise issue has occurred to me, and would be a turnoff. In addition to my own objection, I might never get Maureen to ride with me again. A very last resort, I think.
    I appreciate being able to add your thoughts to the mix.
    Rich Phillips
    Member #27
