Results 1 to 8 of 8
Thread: WVO and ring coking
    Feb 2008
    Kentucky and Clemson SC
    Default WVO and ring coking
    Here is a question for all you WVO users. I have a greasecar/custom kit in my truck and it runs great on both diesel and WVO. I only have put maybe 5000 miles on wvo though.
    While poking around on the internet, I have come across several sites that talk about the need to get WVO way hotter than our grease car type systems get it. They are saying 230 F is the minimum to get WVO to diesel viscosity and avoid piston ring coking, poor atomization, cylinder wall wear and premature engine failure. Makes sense to me, if the info on viscosity is legit. Their solution is to use injector line heaters like fattywagon.com sells.
    take a look at
    http://voconversionbasics.websitetoo...ost?id=1644578
    and
    http://biodiesel.infopop.cc/eve/foru...51/m/725107971
    Thoughts?
    Sold: 98 2500 ext cab long bed 4x4 auto 166k, Lubrication Specialties oil cooler, FSD cooler, Walking J "feed the Beast" mod, Heath HD lift pump, SSdiesel turbo back exhaust, Heath mechanical boost controller, Softtopper camper top, boost, egt, fuel pressure gauges
    1970 El Camino SS, built 355, aluminum heads, Lunati cam, intake, 800 cfm edlebrock, Tremec 5 spd, QA1 Coil over all around, Wilwood discs up front, 3.73 Posi 12 bolt, Viper Red
    2012 Audi A3 TDI- Love it! 45 mpg!
    May 2009
    NH & Eastern NY
    I would be concerned with the high heat in regards to the IP, injectors and return lines. This is the main reason I've been working on test batches of home-brew biodiesel. The heaters draw lots of juice, and may be deterimental to the fuel system.
    Feb 2008
    Well the proposed injection line heaters are placed on the metal injection lines right before the injectors so it would be after the IP.
    May 2000
    Portland Oregon US
    Quote Originally Posted by Kmehr View Post
    take a look at
    and
    Thoughts?
    That would be too hot. Thier are several factors that can cause coking. Early switching before your engine is up to full operationg temp, VO not up to temp, and too short of purging. I would suggest you get a heat guage and check what the temp is of the Vo before it hits the IP> I have had 2 trucks with Greasecar kits and the first one I did add a Heat therm inline before the IP for additional heat and on my D max non is needed. Between both rigs i have over 190000 miles on VO without any issues.
    2006 LBZ Duramax CC/SB,Line-X,Advance Fold a Cover, 2WD, 4" Aero Turbine Exhaust, Isspro Gauges A Pillar,Westin Nerd Bars.Blocker Plate. Burkhard PCV Re-Route
    Greasecar Kit with Automated CoPilot, 200 gal WVO tank. Inline Particle Counter for ISO rated WVO Cleanliness.Time to go fishing, Now I pass everything including the fuel station. .
    Feb 2008
    I have a heat gauge that measures the temp of the fuel right as it comes out of the filter (so pre IP and injectors) and it regularly stays at 135-150 without using my veg therm(electric inline heater). I have the Veg therm right after the fuel pump so it gets additional heat before the IP. I am going to move the temp sensor to right after the fuel pump to get a closer reading on what is going to the injectors. I have been very satisfied with how my truck runs on WVO on all but big hills at highway speeds (starts to miss and chug if I don't lift my foot a little doing 75).
    However, the main thing I am asking here is how much heat do we really need? Coking the rings and causing big problems would really suck. Is the difference in viscosity of the WVO at 140 and 240 really significant?
    May 2000
    Portland Oregon US
    180 to 190 Deg with your veg therm it will get thier. In regards to running your 6.5 under load I had he same issue Need a lift pump to compesate for that and it solved the problem. If you search the greasecar forum on 6.5s you will see lot of info on it including my 99 burb. I would not worry about coking. Sounds like you are doing things correctly. One tip I got a grill cover for the winter from Cabelas and that really helped on faster heat up and higher VO temps. Good luck
    Feb 2008
    thanks, I think I have seen your burb on there quite a bit, I have actually posted on that forums with my various install issues haha. I actually have the Pureflow technologies Raptor pump, which provides tons of flow and I still get the chugging. I put a t valve in my fuel line after the raptor with a ball valve on it to i can purge the air out. No matter what I seal or how long I run the pump (hot wire the raptor and run a clear hose back to the tank) I still have air bubbles. Think thats the issue? any suggesstions on how to fix it?
    May 2000
    Portland Oregon US
    IT could be the issue I would track that down. More likely is unless you have at lease 20lbs of pressure on the HIH greasecare supply line you wont' get enough flow to prevent the stalling. THat is what I discovered on my burb I could run up to 100 towing my boat with no issues. I would also check your tank to make sure you vent is working so you don't starve from not enough air getting into the tank to alow fuel flow. Try taking off the fill cap and check it with it off.
