The Corvette servo is simply a big piston actuator that applys clamping force to the 2nd gear/rev band on the drum. With a shift kit it may produce a harsh shift, but the accumulator springs will really dictate that, not necessarily the servo. This is a great mod and really helps with the life and durability of the unit.
I can't remember what the TV cable is hooked to within the valvebody, but you'll want to pull the pan and take a look. I haven't had one open for more than 15 years, so hopefully someone else here has a better answer for you.
