Hello,
I just got this truck a few weeks ago, its a 94 GMC 2500, 6.5 turbo, 5 speed, 4x4.
The original 6.5 was bad so I pulled the 6.2 out of my old rusty Suburban, put late model 6.5 heads on it and all the other 6.5 stuff originally on the 94 truck. The 94 6.5 heads were cracked really bad.
I installed rebuilt injectors, made a rig to test 4 glow plugs at a time on a battery so I know they all work and heat up in the same amount of time. I know the short block is in good shape.
It has a Heath chip and a manual boost control.
It starts great in cold weather. The video link below was after a cold start at just above 0 degrees F, problem is after the start it makes TONS of white smoke and pops and farts for about 6 minutes before it finally runs on all 8 cylinders. It was the same deal this morning at about 35 degrees F.
I have tried the stock chip in the computer, another pump driver, advancing the pump a little but nothing helps. If the wind blows the smoke at the house the whole house smells like diesel inside. It makes me feel sick if I am anywhere near the smoke it as it warms up.
Did I lose too much compression with the late model {2000 I think} 6.5 heads? I could get my compression gauge in only 7 cylinders, could not get in the back pass side without removing the down pipe. I had 360 to 380 psi compression on a slightly warmed up engine.
I am starting to wonder if there is a problem with a couple of the rebuilt injectors I got.
After it warms up it runs great, in fact it hauls a$$ for a old 6.2, 85 mph in 4th gear in no time at 12 lbs of boost.
What do you guys on here think? Should I pull the injectors and have them tested? I am about out of ideas otherwise.
Just to make it clear it starts awesome at 0 degrees without block heater, the problem is smoking out our yard or the neighbor's yard after it starts.
