dead accelerator pedal
Sometimes, about every 15-30 miles, usually after a decel or take off from a stop the engine will not pull. Very slowly gains speed like a very soft take off even if you push pedal to floor. Usually as pedal about reaches the floor the engine will begin to take off if the pedal is not eased up quickly enough the engine goes like a full throttle start. Next 10 miles may be normal. NO codes!!, yet.
2004.5 LLY with or w/out Edge does it more often with Edge.
Has anyone run into this problem?? TIA
Bob O.
2004 K2500 DA LLY CC LT LB Wow! Edge w/A + BS + CAT pre fuel filter, 06 air box,
2002 C6500 EC. 7.2 Cat NoMar rollback/ 92 C7500, 7.2 Cat, 25ton No-Mar / 2005 C5500 D/A rollback / 1969 Corvette 350-350 4spd AC T-top stock orginal
XP850LE WOW nice ATV, 09-550XP hers, 03-Predator, 04 Honda400EX, 05-Banshee, 08-KTM525, 08 KFX700, 38' enclosed GN hitch
