I got a little problem with the 96 GMC 6.5TD vin code S truck. I got a steal of deal on the sucker it has 324km and runs great just had a little studder at low speads app sensor code P0227 easy enough found a gas pedal out at the farm. Cleared the codes now i got 4 new ones and still have a hesitation and get the odd no start. Couldnt tell you when the pump was done or pmd but it is the gray one so had to be somewhat recent.
The new codes are
P0404 EGR System Performance
P1214 Injection Pump Timing Offset at 4.5
P0216 Injection timing circuit
P1218 Injection Pump Calibration Circuit
Now when i get the no start i pop the glove box give the pcm a wack and bang fires up.
The other thing is when the scanner is hooked up to the truck it runs like **** and stalls out and there was a reading that i'm drawing a blank on what it is exaclty that the number is suppose to be low but its at 8690 reguarding the pcm.
Any ideas i really dont want to do the pcm cause if i do then i got to buy gauges and an exhaust cause i'll chip it at the same time which was suppose to be down the road. Thanks
