Results 1 to 9 of 9
Thread: I am thinking about grabbing a Ford built diesel engine, input needed
    May 2008
    Columbus GA.
    Default I am thinking about grabbing a Ford built diesel engine, input needed
    I have a 1968 Ford crew cab and a Cummins I planned to mate together. However, I recently found a Ford built straight six diesel engine. I think it is for a marine application. Anyhoo, I sure would love to drop a Ford engine in that old Ford pickup. Here is the problem, I know nothing about them. I barely know enough about the Cummins to drop it in and get it running. The Ford engine is really the way I would like to go but I have to make sure it will fit my needs. I have been all over the internet trying to locate information but I think I am looking in the wrong areas. Can someone please guide or help me with this. My window on buying the engine is closing and I have to make a well informed decision quick.
    These are the only numbers I have from the Ford engine:
    REF 5503
    TYPE 212C
    1995 Ford F350 Crew Cab Dually with a 7.3 liter Powerstroke
    198? Chevy aircraft tugger with a 6.2 liter "Tugger"
    Windham, ME
    Without actually seeing the engine I'm going to guess it's either an FD1060 or FD1460, hopefully that's enough to get you going.
    Phil
    May 2008
    Columbus GA.
    I did continue to search and I think I knwo what it is. I think it is a 6.6 that Ford use to run in thier medium duty chassis.
    Sep 2006
    If it's a 6.6, here's more information:
    http://www.ford-trucks.com/forums/79...wap-ideas.html
    If would be an interesting swap if you end up doing it.
    Good luck...........
    1990 ¾ ton 4x4 Chevy Suburban
    -Gear Vendors Overdrive
    -Upgraded Holset HX-35 turbo
    -NP205 iron transfer case
    -3.73 gears
    1982 ½ ton Chevy Suburban
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
    May 2008
    Columbus GA.
    Thanks for the link. I think is would be oh so cool to have that Ford engine in my 68 Ford. But the the Cummins would be sooooooooooo much cheaper. I am torn here.
    Apr 2004
    Ottawa, Ontario
    You might try a search under "Ford Leahman". Very popular marine engines. Also used as industrial engines and in a few bus/automotive applications. Both Volvo and OMC used to use the 4 and 6 cyl versions with their outdrives. Very popular with the trawler crowd because of their fuel economy. As far as I know, they used the conventional Bosch pumps so an automotive equiv would be easy to locate.
    Bill
    94 Cadillac Fleetwood (sold)
    08 Aerolight 23TT
    Windham, ME
    I learned something from this thread - that the FD1060 & FD1460 are just the Cummins 5.9l & 8.3l, and that our '87 F600 avgas truck, which according to the VIN has the 1060, was apparently repowered with a 6.6l atcsome time. That sheet metal valve cover ain't no Cummins LOL
    Phil
    May 2008
    Columbus GA.
    Thanks. I will check them out.
    After I started looking and asking I have found these engines to be more common than I thought.
