I am having my 6.5 rebuilt, unfortunatly i can only afford a stock rebuild. But I am going to make a few additions. The truck already has 3" all the way back with a 18" glasspack and 4.5" Chromy. I am adding a Heath chip, Heath Turbo-Master, and a aFe cold air performance intake. Is there anything else , were talking cheap here, that can be done?
What should the boost be set to?
Is the TDC the injector pump setting?
Can I do that and will it help?
I am relativly new to this. My engine ran for 201,000 miles without a major problem so I never felt the need to help it out. Now that the motor is out I want to get the most I can out of it.
Any help would be appreciated!
Bbubus
94' GMC K2500HD, Heath chip, -1.94, Turbo-Master, AFE Cold Air Intake, Bosch High Flow Injectors, 3" Exhaust all the way back, 4.5" chrome tip(exhaust sounds sweet), Heath Turbo Down Pipe, Heath Crossover, IssPro gauges, Three Pod Piller, 98' Cooling Mods, DMax Fan, High output water pump, DSG Oil Cooler, Heath PMD kit, Light kit with high output bulbs(very bright...finally)
