On my 95 suburban I started to see a problem a while back, The radio and wipers would not shut off with the ignition key. After a few weeks of this, everything went back to normal. This lasted for a month or two and then it went back to the radio and wipers not shutting off again. I figured that the ignition switch was the problem and since this seems to be a problem area I decided to change it. Yesterday I replaced the ignition switch and still have the same problem, Radio and wipers do not shut off with the ignition key. Does anyone have any ideas on where to go from here?
N9Phil
