Sometimes that works, sometimes it doesn't. Sometimes if you do that, you get backfeeding through the turn signal switch, and everything lights up at the same time.
Whenever we wire up vehicles to tow behind motorhomes, we always run dedicated wiring along with diodes, to prevent any feedback. This separates the two systems.
