Thread: 4 cylinder DD engine in 72 Chevy truck
    Default 4 cylinder DD engine in 72 Chevy truck
    Am interested in a 72 Chevy w/a four cylinder Detroit Diesel engine in it. The owner stated the the engine was a "4cc" DD and that the engine is not original to the truck. Past that, the owner doesn't seem to know much about it. Anyone have any clue as to which DD engine model it might be?
    Sep 2006
    It's most likely a Detroit 4-53 which is a 2 cycle, 4 cylinder engine having 212 cubic inches. In stock form, it had 135 hp.
    They're not so fuel efficient but the engine does make a cool sounding exhaust note.
    1990 ¾ ton 4x4 Chevy Suburban
    -Gear Vendors Overdrive
    -Upgraded Holset HX-35 turbo
    -NP205 iron transfer case
    -3.73 gears
    1982 ½ ton Chevy Suburban
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
    Windham, ME
    They also do best when they're wound right up, when you're operating a Detroit-powered piece of road equipment you pretty much keep the accelerator on the floor and control road speed with the transmission LOL
    Phil
