I'm not an AC guy...but I think it would be helpful if you posted what exactly is going on and what you have tried...be detailed...the more info you post the better chance of a solid response you have..
95 Suburban 1500 Bone Stock Orig.
purchased at 103K from first owner
new alternator/autozone gold @104K
re-trannyed with shift kit @107.5K
new Bilsteins all around @ 127K
Kennedy exhaust @128k ..zoom!
new lift pump w/OPS bypass @ 130K
Kennedy FSD cooler @ 135K
New IP/Injectors/G-plugs @ 137k
Another autozone alternator and Optima Reds @ 150K
Another pump and injectors @157K
New chain and gears @157K
HO pump single therm setup @157K (will see what happens)
Head gasket or worse to be determined...164k
NEW AM General 6.5 installed and running well! @ 164K!!!!!
