Lots of 6.2 6.5 and 6.5TD parts for sale
MLSC 6.5/6.2 Parts For Sale
DB2 fuel injection lines set of 8 $50
DB2 throttle cable, good used $35.00
6.5 Oil Pan, good used $25.00
Set of freeze plugs (new) $10
Engine bearings, for non oil squirter block, main & rods, test run only, PM for details
Factory GM crank dampers for electronic 6.5 Diesel engines, part 10154688.
1 very good $40, one good $20
Crank Damper Installer $25.00
4WD oil filter adapter, like new, $20.00
Aluminum front timing chain cover, $25
Steel back cover for water pump, $20
Serpentine fan belt pulley $20.00
2 rebuilt 6.5 fuel injectors $40.00
Radiator overflow bottle, 1995, $25.00
Factory oil cooler with upper mounting bracket (no lower) $25.00
Hummer hydraulic fan clutch, fan & lower 4 V belt pulleys and water pump & backplate , test run only $50 for all
1993 Turbo Diesel Exhaust manifold, passenger (turbo) side only, $30
Crank timing chain gear for electronic engines with reluctor cast on, like new, $15.00
Flex plate for 6.5 with 4L80E $25.00
Heater hose clip PN 15613086 New, $5.00
4L80E transmission yoke, 2WD sliding type $25.00
Cover for trans/flex plate $15.00
All parts used unless stated otherwise. Prices do not include shipping.
Bobbie Martin
1995 Chevrolet Suburban 1500 6.5 TD 2WD- DB2 mechanical fuel injection
GEP Optimizer 6.53 Detroit Diesel Power
6.53L, GEP Block & Heads, .020 over, ARP studs, DB2 Inj. pump, GM8 Turbo w/TurboMaster
K47 Airbox with K&N filter, 3" mandrel bent exhaust, 2ΒΌ" Crossover, Mann ProVent
HO Water Pump, Hayden "Truck Fan" Clutch, 21" 9 blade Duramax Fan
No PMD, APP, CDR, optical sensor or vacuum pump!
Author of The DB2 Conversion Guide
Click Here to Email Me
- You may not post replies
- You may not edit your posts
Forum Rules
