Hello,
I have a thread running here, but wanted to ask on main menu specifically about the lift pump diagnostics? So you can reply here or in the thread link below.
http://www.thedieselpageforums.com/t...ad.php?t=37776
OK, as noted in the thread above, I swapped my 5 year old lift pump that seems to be working perfectly, based on always running anytime I turn on the switch.
But I am trying to diagnose the stalling issue, making sure the lift pump is good...? I suspect it is, but wanted to make sure and eliminate it.
I swapped out my seemingly good lift pump of 5 years then installed a backup lift pump that worked pefect when I swapped it out for maintenance 5 years ago and kept it for a traveling backup lift pump.
I swapped it out and when I first turned on the key, it worked fine pumping away...
But then after that first run it never turned back on again... then subsequent times of running the truck and trying to bleed the air out of the system, that lift pump refused to pump fuel to bleed the air out and would NEVER turn back on after the first time. It never worked again after it first pumped, I suppose it locked up from sitting wrapped up for 5 years? I did have the ends capped and in a zip lock bag. so it did NOT rust or anything. Does ANYONE have any thoughts on a lift pump locking up? I suspose she is toast and to toss it...
Thanks again for all your help!
