Trailer Charging/Voltmeter Question
Today while pulling a pop up camper home the voltmeter dropped to around 12-12.5 volts. Since I have had the truck it has always been at 14. The pop up has a deep cycle marine battery that was fairly drained after running the heater all night and we didn't charge it all before we left camp.
We have installed the fuse under the hood to allow charging, and the only very informal test we ran was to check the trailer voltage, and test it again with the truck hooked up and it showed higher. Normally we charge the battery before we leave for the trip and again the morning we are leaving camp so this is the first time it has actually been low and hooked up to the truck
The volt meter would return to near 14 for awhile and then go back down. No warning lights came on. When we got home bot batteries were reading 13.5 with the truck idleing and still hooked to the trailer.
So my question is, is it normal for the voltmeter to show a drop that large while hooked to a trailer or should I be concerned about the alternator.
Sorry this is so long
Sam
2001 summit white ext. cab D/A
