Towing, and the Rockies can both be a creator of heat. Heat will kill almost anything. As stated above, do you have a boost and a pyrometer gauge. If not install them as soon as you can. Why? With gauges you can see what is going on when things are going good, and when you have a problem, they will change, ie; low boost, high exhaust temps.
You did not mention if you have had any performance items installed. So if you are stock, lets look at the basics. There is the possibility that you could have air in the cooling system, but they should know how to bleed the air out prior to sending you on the way. A collapsed lower radiator hose, or a restricted cooling system, bugs and other debri in the radiator core or A/C condenser. Anything in front of the grill? Like bikes, spare tire, anything that would restrict air flow to the radiator. A bad fan clutch, can you hear it engage when it gets warm? Do you get black smoke under acceleration, or on a hard pull? This could be from lack of boost. That could be as simple as stated above, a vacuum hose not connected, or a vacuum leak. The boost solenoid, boost sensor, vacuum actuator diaphram leaking. To much fuel, from a bad injection pump, leaking injectors.
What about an exhaust resriction, clogged soot trap (converter).
When towing in the high temperatures, a few things add to the mix. Pulling hard and when the torque converter unlocks, the transmission creates a lot of heat, 280*F+ and even higher, which then enters the radiator to be cooled. That also helps heat the coolant. Plus you are going slower and less air is forced through the radiator, and now everything depends on the fan if the clutch is functioning properly. Is the A/C on as well? Thats more heat.
You said it runs hot. What was the coolant temps? Were they over 210*F? If so thats getting to the danger zone.
I would suggest a 12-V fan cooled transmission oil cooler, as this will save both the transmission and the engine, by keeping everything cooler.
Lets have some temps etc. so we can all help you. Wish you well. [img]smile.gif[/img]
Tom McCauley (DP Member #513)
