Do you know which center section has been used on these hitches? The original 959 center section from B&W will bolt up to the new 2011 models, but B&W redesigned them and labeled them 959N (IIRC) to better fit the hydroformed rails. I'm a B&W dealer and received an email from them saying not to use the 959 center sections on the 2011 trucks.
I'll double check the part numbers when I get to work in the morning.
