.007" is fine.
The spec is really .006" so I think you'll be just fine with the standard thickness .045" gasket. Are you using your bridge and dial guage at the center of the piston?
The varying you're seing is most likely the rod length, getting the rods all the same length is quite a process on these engines and it's very crucial.
J
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
