I didn't know they even made a V-belt vacuum pump!!
Is this a standard front-mounted engine? If so, you can remove the doghouse cover inside the coach to gain access to the engine. At the very rear of the engine in the center of the valley, you'll probably find a round plug. This is where the gear-driven vacuum pump normally resides on these engines. This is the same location where a distributor would be mounted on a Chevy gas V8. GM/Detroit decided to keep the same setup for the diesel engines to run the oil pump and the vacuum pump, until they started using a serpentine belt setup and went with a belt driven vacuum pump.
