I get 30 mpg out of my 1982 6.2 diesel Suburban at a steady 55 mph. However, the engine is geared towards fuel economy rather than power such as having the older heads with small precombustion chambers, 3.08 gears and 700r4 overdrive transmission. The Suburban is also the most stripped down model with no A/C so it's lighter weight that most. However, it doesn't get as good fuel economy towing a large load like my other Suburban with the Cummins probably because it has to work so hard.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
1982 ½ ton Chevy Suburban
-Stans headers
-Ported heads
-Timing gear
-4 speed automatic
-3.08 gears
-30 mpg on freeway
