Hello,
im new here and from the netherlands.
Dont know much about die Dmax engine have to read complete forum
Preparing my lb7 (2001) to run on europallet.
Cutted of the TCM-harness no need for found only three/four cables running to the fusebox or ECM.
Much difference in dealing with used carparts between states and europe. I know from TV that every seller in USA has to document on each used part from what car its a take out (VIN).
I bought the engine from german (near Heidelberg) scrap yard only know that its from damaged US-military Chevy (total loss). Without ECM
Please some questions.
Where to connect the OBDII cable and the fly by wire?
Im in need of wiring diagram.
its possible to find the VIN on the engine? I saw some curillic signs near the bellhousing flange.
Does the engine start if i buy a new/used ECM with different VIN? Because of the FICM: does the ECM compare the stored VIN with the one from the FICM? Or isn't there one VIN programmed inside the FICM?
Where is the immobilizer? Inside the BCM? Does ECM ask for one signal from immobilizer?
Is there online spare parts catalog? Need clamb from exaust pipe, cover from fusebox, enz.
Thank you very much
Willi
