If its a K-series....have plenty of patience for the drivers side!
The mount is right up against the front differential which limits access to the nut/bolts....impossible no...frustrating as hell...yes.
The nut bolt combos are self-locking so will need two wrenches on each.
Enjoy
Kennedy exhaust @128k ..zoom!
Kennedy FSD cooler @ 135K
New chain and gears @157K
